JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Diggie3
Jan 09, 2018Luminary
Not pointing the finger at the last post specifically, but I think we should not talk about stability until we have 48 hours under our belts. All that happens is someone posts "1.0.9.x seems stable" and then again the next day with "nope, turns out it wasn't!".
ryanvellia
Jan 09, 2018Aspirant
Thish as been happening for a couple of months now on my router, through multiple firmware updates.
Can anyone share a link on how to revert bcak? I'll probably try and go back to a firmware from around a year ago if possible.
- dnbasJan 09, 2018Aspirant
Going back doesn't help.
I went back to firmware 1.0.5.70_1.1.91 from 1 year ago and problems stays.
Now for 2 days on XWRT-VORTEX and seems oke now.
- rogier64Jan 09, 2018Luminary
dnbas wrote:Going back doesn't help.
That's exactly my experience. It looks like something is screwed up after a certain FW upgrade. Going back to older FW doesn't solve it. I run XWRT-Vortex for about 8 months now, definitely won't go back to NG FW.
