JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
ryanvellia
Jan 09, 2018Aspirant
Like I said I'm limited as far as routers go, I've never flashed firmware before.
Ouin
Jan 09, 2018Tutor
Be careful that Xwrt-Vortex is not an open source firmware and we download only a compile version. We should thrust a Russia site and be sure that there are no spy process inside!
- vincentw56Jan 09, 2018Tutor
Ouin wrote:
Be careful that Xwrt-Vortex is not an open source firmware and we download only a compile version. We should thrust a Russia site and be sure that there are no spy process inside!Because ALL Russians are bad.
- shamarinJan 09, 2018Virtuoso
Thank you! This is a compliment for me and for all people in my country.
- BradR7000Jan 09, 2018Star
What does Xwrt-Vortex have that Advanced Tomato does not?
- rogier64Jan 09, 2018Luminary
Advanced Tomato has more options than XWRT-Vortex. More options doesn't mean better, in most cases you do not want to touch the features because you can screw up a lot. XWRT-Vortex for R7000 is a port or XWRT-Merlin which is based on the Asus firmware (based on Tomato). As XWRT-Vortex uses the HW-acceleration drivers (just as NG does) it has no limitations in WAN to LAN speed like most of alternative firmware do have.
