JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
spanishgringo
Dec 18, 2017Tutor
So far everything is working fine. I had had troubles with .12 and 14 so I flashed back to 1.0.9.6, did factory reset. Updated to 1.0.9.18 today and speeds and connectivity have been good.
AlpineKid66
Jan 09, 2018Guide
I hope it works for me.
- rogier64Jan 09, 2018Luminary
AlpineKid66 wrote:I hope it works for me.
I'm sure it will :-)
