JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
rogier64
Jan 09, 2018Luminary
If you're flashing from a Netgear firmware you have to use the .chk file. If you are on XWRT-Vortex firmware you must use the .trx file. Please be aware that you will get a warning that the firmware is older than installed now. Ignore that message and proceed with flashing. Also booting takes a longer time. Just sit down, relax and wait for complete boot.
dnbas
Jan 09, 2018Aspirant
What rogier64 writes is correct, I only had problems with the logging of the router after loading this FW. I didn't get in because username and password where gone. After 2x reset of the router and several tries I got the setup wizard. After that it was a piece of cake.
- CrozzaaJan 09, 2018Aspirant
Cheers for the help, Can you please tell me if "Nat Filtering" is on the firmware?
- rogier64Jan 09, 2018Luminary
Before going into detail, there is a lot of info on http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
