JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Rikardo007
Jan 09, 2018Tutor
So to confirm, if I am flashing from stock Netgear firmware, I only need to load the .chk file?
I found this tutorial (http://avi.im/blag/2015/asus-wrt-merlin-on-netgear-r7000/) posted in another thread which says you do the .chk to get Tomato then the .trx to get XWRT-Vortex.
xerocypher
Jan 09, 2018Aspirant
Correct. I followed the initial flashing instructions in the link provided by rogier64. Pretty straightforward and everything seems to be running smoothly so far.
