JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Rikardo007
Jan 09, 2018Tutor
So to confirm, if I am flashing from stock Netgear firmware, I only need to load the .chk file?
I found this tutorial (http://avi.im/blag/2015/asus-wrt-merlin-on-netgear-r7000/) posted in another thread which says you do the .chk to get Tomato then the .trx to get XWRT-Vortex.
rogier64
Jan 09, 2018Luminary
Rikardo007 wrote:So to confirm, if I am flashing from stock Netgear firmware, I only need to load the .chk file?
If you are on NG firmware go to the GUI page where you can flash the firmware. Just flash the .chk file as you would do with NG firmware. It is being adviced to do a factory reset before flashing the XWRT firmware to avoid out of memory issues.
- jomihiJan 09, 2018Aspirant
Hi all,
back again with some bad update: after nearly 48 hours with 2.4 ghz (and 5.0) my router runs out of control again. 2.4 went down, 5 becomes unstable as well. To make it more worse my console freez and I had to reset the router to come back to live.
As I don“t see any offical regular updates nor any offical recommendation how to handle this bug nor any other reaction it seem to me that Netgear is happy to loose customers.
@ Netgear: if I am right with my assumption pls. do nothing, than I know how to advise my private community and my fiends in the field.
Now a bit more than not happy
Michael
- tulongJan 09, 2018Guide
As promissed, I am back here with the result. After flashing the router with Advanced Tomato and let it run for 12 days straight, I am a happy camper. The speeds on both channel are pretty stable. 2.4Ghz has been solid 300Mbps and 5Ghz. has been around 480-560Mbps measuring from 30 ft distance (mind you, it's not as fast as Netgear has advertized even before I flashed the firmware anyway) Wi-Fi dropping has been a talk in the past and my sons are extremly graceful for what I have done LOL. You will have much more advance features in Advanced Tomato and the GUI is responding way faster. I've seen people hear asking if you still can do NATing and the answer is yes you can NAT up to 5 IP addresses. My advice, flash your Netgear router with either Advanced Tomato or DD WRT and dump the Netgear brand entirely. Trust me, you would be much happier. This will be my last post. Signning off.
- ryanvelliaJan 09, 2018Aspirant
One last question.. will flashing the firmware with a third party version cause issues for my wife's work VPN?
- vincentw56Jan 09, 2018Tutor
ryanvellia wrote:One last question.. will flashing the firmware with a third party version cause issues for my wife's work VPN?
I am on the XWRT-Vortex firmware and use several different VPNs with no issues at all. I am a consultant so I have different customer VPN clients.
- hurricane28Jan 10, 2018Guide
The firmware problem is still not fixed yet..?
I read nothing but negative here.
- rvcjewJan 10, 2018Tutor
I could not take the dropouts any longer and it was also affecting my LAN speeds and one wired printer was constantly dropping.
I am now on xWRT-Vortex v.380 and It is night and day, I didnt even bother to factory reset before going to it as i knew my memory was good as i rebooted before flashing the .chk and it went off without a hitch. I now have all my devices stable for over 48 hours and my dropping printer and zycel extender just showed up instantly. On the stock FW I would have to reboot my printer to get it to even be pingable again let alone show up then it would just drop off after about 30 minutes. The extender took a few hours each time. My family has seen consitent and improved speed on the wifi throughput as well. I also like it's just barebones what you need or don't and no disney crap or other stuff. At this point if your going to ditch the device and don't want to be on a lower stock FW then give this a try first. I will be letting the comanpies (around 25) that have been asking me about their dropouts to go to this FW and not touch stock again for the time being.
Good luck to all still hanging onto Neatgears slow and very had handling of this issue going forward. To the ones running Debug firmware I hope you can help them resolve this.
Malcolm
EDIT: also wanted to say that I have the same setup as before for comparison on the stability:
2.4 and 5ghz bands with seperate SSIDS and passes both with ACL on and two guest networks.
- AaronB483Jan 10, 2018Aspirant
When installing Tomato firmware, I forgot to follow the instuctions to first do a factory reset.
It was unreachable. I thought OH NO, I bricked my router. But doing a reset afterward alowed me in.
It is nice when logging in to see the status page showing the tempetature of the cpu and the radios.
- rogier64Jan 10, 2018Luminary
AaronB483 wrote:When installing Tomato firmware, I forgot to follow the instuctions to first do a factory reset.
It's hard to brick a R7000, that's also one of the reasons I love the R7000 hardware. If you really screwed up you can flash in recovery mode of the router.
