JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
hurricane28
Jan 10, 2018Guide
I got an email from Jack Chen if i am willing to run their debug firmware but unfortunately i have no time for testing.
I hope someone with more time can test it in order to help the Netgear engineers to solve this problem.
I will follow this thread for further updates.
Cheers.
Crozzaa
Jan 10, 2018Aspirant
I just upgraded to the "wrt-vortex" firmware, Now if i was to revert to NG Firmware how would i go about doing so in the future?
- xerocypherJan 10, 2018Aspirant
Crozzaa wrote:I just upgraded to the "wrt-vortex" firmware, Now if i was to revert to NG Firmware how would i go about doing so in the future?
It's usually as simple as uploading the stock firmware like you're upgrading the 3rd party firmware. But in the event it isn't you can try what was outlined here:
r7000 - How to revert from DD WRT to NetGear Factory Firmware
- rogier64Jan 10, 2018Luminary
Well, not that easy. In XWRT-Vortex you can only flash .trx firmware files. As NG uses .chk files it will not work for XWRT-Vortex. In the forum (lots of interesting information) http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/ you can find on page 1 the download link for old NG firmware version 1.0.3.80 in .trx format, you can use this file to flash from XWRT-Vortex to NG stock.
- armelwaniJan 10, 2018Aspirant
I started having problems at 1.0.9.12, figured Netgear was aware and updated to 1.0.9.14 and 1.0.9.18 whenever they were released. With 1.0.9.18 I couldn't go 24hrs without my 2.4GHz dropping out. My Honeywell Lyric thermostat and my WeMo Switches were always the first things to stop responding, and then my Echo and Echo Dot. Rebooting the router, or making any change to wireless (changing channels became a regular occurrence), would bring it back for a short time.
After spending way too much time fussing with it, I came here and read through this whole thread. I dropped my router back to 1.0.9.10 (last stable version I had) and was good for about 48hrs, then the 2.4GHz issues began again. 5GHz never had an issue (although speeds were terrible on 1.0.9.18 which was the only version I did speed tests on).
So, I went all the way back to 1.0.7.12, which seemed to work for most people on here. It did for me for about 72hrs. I really thought I was out of the woods, everything was speedy and running stable. Then, one evening, out of nowhere my Echo chimes that she's having issues connecting to the Internet. I checked my WeMo and every switch was offline. 5GHz was fine. Dammit.
At my wits end, I've taken the advice of several folks and yesterday morning did a factory reset and flashed XWRT-Vortex 380.69. After flashing (which was painless, BTW) I did another factory reset and reconfigured all my settings. 2.4GHz and 5GHz with different SSIDs and PW, single guest access on 2.4GHz (we have a duplex and provide WiFi to our tenants), no ACL and no QoS (I have 150Mbit XFinity connection).
Whole process took me less than an hour, and although it's only been 24hrs since then my speeds are still very fast and both bands and guest access have been rock solid. I'm impressed.
The hardware appears to be pretty decent on this router, just a shame Netgear can't get the software working correctly. I will report back again after a few days of testing, but as of right now I'm a happy camper running XWRT-Vortex.
- HWAMJan 10, 2018ApprenticeI had exactly the same problems. And I also wasn't able to make it stable again. I bought a new Linksys WRT1900ACS. I needed a stable solution very quickly. My R7000 runs Advanced Tomato now. I use it as extra access point on the first floor. I have no good words for Netgear. It is totally over for me. Never Netgear again. Such a shame they can't fix it. Even using an old firmware is not stable anymore. How is that possible? And no communication about the reason or the status at this moment. What a terrible company.
