JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
armelwani
Jan 10, 2018Aspirant
I started having problems at 1.0.9.12, figured Netgear was aware and updated to 1.0.9.14 and 1.0.9.18 whenever they were released. With 1.0.9.18 I couldn't go 24hrs without my 2.4GHz dropping out. My Honeywell Lyric thermostat and my WeMo Switches were always the first things to stop responding, and then my Echo and Echo Dot. Rebooting the router, or making any change to wireless (changing channels became a regular occurrence), would bring it back for a short time.
After spending way too much time fussing with it, I came here and read through this whole thread. I dropped my router back to 1.0.9.10 (last stable version I had) and was good for about 48hrs, then the 2.4GHz issues began again. 5GHz never had an issue (although speeds were terrible on 1.0.9.18 which was the only version I did speed tests on).
So, I went all the way back to 1.0.7.12, which seemed to work for most people on here. It did for me for about 72hrs. I really thought I was out of the woods, everything was speedy and running stable. Then, one evening, out of nowhere my Echo chimes that she's having issues connecting to the Internet. I checked my WeMo and every switch was offline. 5GHz was fine. Dammit.
At my wits end, I've taken the advice of several folks and yesterday morning did a factory reset and flashed XWRT-Vortex 380.69. After flashing (which was painless, BTW) I did another factory reset and reconfigured all my settings. 2.4GHz and 5GHz with different SSIDs and PW, single guest access on 2.4GHz (we have a duplex and provide WiFi to our tenants), no ACL and no QoS (I have 150Mbit XFinity connection).
Whole process took me less than an hour, and although it's only been 24hrs since then my speeds are still very fast and both bands and guest access have been rock solid. I'm impressed.
The hardware appears to be pretty decent on this router, just a shame Netgear can't get the software working correctly. I will report back again after a few days of testing, but as of right now I'm a happy camper running XWRT-Vortex.
jmooremcc
Did you check to see if you have interference on the wifi channel you are using from neighboring routers? If not, this free Android app (Wifi Analyzer) can be used to help you determine the best wifi channel to use:
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en
I've been using it for a number of years and find it very useful.
- HWAMJan 10, 2018Apprenticejmooremcc With all respect but I work in the ICT for more than 25 years. I know what I am doing. I use channel 13 for 2.4GHz for years and also with my new Linksys WRT1900ACS now. After updating a lot of people got the same problems. What a coincidence. Netgear broke something and they know. They are working hard to fix it, let's hope. They already made some beta versions, all without success. And I know the analyzer app, who don't??
- armelwaniJan 10, 2018Aspirant
That's a good point to raise. I used several different WiFi Analyzers to make sure I wasn't on an over-utilized channel. For my neighbourhood channels 1, 4, and 11 on 2.4GHz were the most empty, so I would jump between them when I was on 1.0.9.18 to make my WiFi come back. On 5GHz I always stay on 153 which is empty besides me.
Now that I'm on XWRT-Vortex I have 2.4GHz on channel 1 and 5GHz on channel 153. No issues thus far.
