JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
jmooremcc
Jan 10, 2018Aspirant
Did you check to see if you have interference on the wifi channel you are using from neighboring routers? If not, this free Android app (Wifi Analyzer) can be used to help you determine the best wifi channel to use:
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en
I've been using it for a number of years and find it very useful.
armelwani
That's a good point to raise. I used several different WiFi Analyzers to make sure I wasn't on an over-utilized channel. For my neighbourhood channels 1, 4, and 11 on 2.4GHz were the most empty, so I would jump between them when I was on 1.0.9.18 to make my WiFi come back. On 5GHz I always stay on 153 which is empty besides me.
Now that I'm on XWRT-Vortex I have 2.4GHz on channel 1 and 5GHz on channel 153. No issues thus far.
