JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
wifiuser123
Jan 11, 2018Aspirant
I tried every other option and nothing seems to resolve the dropping connection issue after about 12 - 24 hours of each reboot. I have tried Firmware Version 1.0.9.20 (Hot Fix) as well, but no help. I ended up reverting the Firmware to Version V1.0.9.12_1.2.23, and it seems to work. It has been about 24 hours since I reverted the firmware, and no issues so far. My devise is configured as router, so I should be fine in terms of security vulnarability.
brianhelman
Jan 11, 2018Apprentice
I also was able to fix my router. I purchased another vendor's gear and installed it. Done.
Netgear, get your act together and *maybe* I'll consider buying your gear again when I replace my new router in 4 or 5 years.
Professionally, I manage a network of about 10,000 computers; a thousand or so network devices, including high-end enterprise wireless. I kind of understand the troubleshooting. I am patient, to a degree, with vendors since recreating the faults is usually very difficult. HOWEVER, recreating the failures with the R7000 is neither difficult or complex. I do not believe Netgear understands the blacklash on this. I have told all of my techie friends to either flash their R7000 with another (non-NG) firmware or buy another router. I'm still trying to figure out how to work with all my non-techie friends who I (apparently, WRONGLY) advized to buy a NightHawk Series router.
I was PM'd today to work with support. I already provided them with several log dumps. They didn't reply and then came back to me as if they didn't know they had already started to work with me 2 weeks ago! It's very difficult to fix a problem when you can't manage it.
- HWAMJan 11, 2018Apprentice
Hi,
I guess it's time for an update. What is the status? Do you know how many people has problems with this? Not only R7000, I know.
Please communicate!
Do you guys want us all to buy a new brand? Without a daily status report people run away to the shop.
Maybe that is your policy about solving problems.
Grt.
