JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JTB5
Jan 12, 2018Aspirant
I haven't noticed any consistent wifi drops, with the router. But what I have noticed is an issue with QOS.
I've done a device specific QOS rule for my Xbox, and have it set to the highest priority. I think filled in the "Uplink" section with my max upload speed of 5mbps, (4.72 mpbs if running the auto speed test on the page) This setting also seemed to throttle the download speed for the xbox, to the same speed as what the uplink was set to.
I've gotten around the issue by setting the "Uplink" speed to 50 mbps. which allows the xbox to get the max down and up speeds I'm supposed to get.
Also I think it's kind of odd that the router main page would let me know that there was a new firmware available, but in a beta version. One would think unless it's fully tested it wouldn't get pushed out that way.
Just my 2 cents.
shoman94
Jan 12, 2018Apprentice
I had similar issues with QoS with multiple devices so I just disabled it. I'm not worried about my speed anyway since I have plenty. (100mbps).
I also setup all my streaming devices on LAN as much as possible or 5ghz. My phones and laptops also use 5ghz. Low priority devices and my kids tablets and guests run off 2.4ghz.
- CeepeebeeJan 12, 2018TutorJust wanted to add so thoughts of mine after trying a few things.
So I'm running the .18 firmware and whilst I'm having ZERO drops, the speed on 2.4ghz is atrocious. I'm running 5ghz on most appliances and phones to get by but the range is obviously effected.
I tri d turning off the 20/40 coexistence setting which is supposed to speed up 2.4ghz and guess what...it gets worse.
So I'm really stuck here. Seriously considering putting tomato on it unless Netgear can give any update on what's actually happening?
I know another firmware was given to some via PM but I'm not trying that unless it's released as a Beta at least.
Any news..ever..anyone?? - jomihiJan 12, 2018Aspirant
Hi all,
no bug fix, no time line, nothing from offical NG site till now.
Don´t think that is a normal behavior for an US company . Bur for sure not the best reputation to get a bigger footprint in Europe.
Anyhow .. I think I have to swap to Vtex or Tomato. But just in case... do someone have any expirience to go back to original NG SW?
BR
Michael
- rogier64Jan 12, 2018Luminary
jomihi wrote:Anyhow .. I think I have to swap to Vtex or Tomato. But just in case... do someone have any expirience to go back to original NG SW?
BR
Michael
My advice would be XWRT-Vortex, it is rock solid stable and easy to use. There is a way to go back to stock, but I'm pretty sure you won't go back once installed.
- FirepsychJan 12, 2018Aspirant
I'd support XWRT-Vortex as well. Switched to the current version and have had no drop offs. To be fair I haven't tried Tomato so I can't make any statements that 1 is better than the other. I'm just happy to have a stable router at this point. Probably won't go back to NG FW unless I see some happy customers on this thread. Not sure I'd buy a NG when current router craps out.
Well, all customers will be happy when NG give them a stable firmware, still I'll be on XWRT-Vortex. Never go back as it is very stable and has a great GUI. Easy to setup and some nice features.
