JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
armelwani
Jan 12, 2018Aspirant
It's been over 72 hours since I flashed XWRT-Vortex and everything has been rock solid! I can't believe NG can't get their firmware right. Even just looking at the open source Tomato should give them some insight into what they're missing. For me, I couldn't be happier. Well, I guess if NG hadn't caused this problem in the first place then maybe, but honestly I don't think my R7000 has ever been as fast as it is right now...
To answer the question about range, I will say in my situation I am noticing an increase in signal strength. 5GHz in particular has a stronger signal than it used to, and my tenants on the 2.4GHz guest network say their speeds are faster. Hope that helps!
HWAM
Jan 13, 2018Apprentice
droman JamesGL
Give us more information. We deserve it. Did you find bugs?
Are you able to reproduce the problem?
How many people suffer from it?
When do you have a stable version?
Come on!!! ANSWER!!
Come on!!! ANSWER!!
- shamarinJan 13, 2018Virtuoso
Have patience, they will release a new version. Or if you problem is so big wrote a personal massege to JamesGL or other admins in this forum with describing of you problem. For me i didn't have any issues with Wi-Fi connections. I have only a problem with VOD services and IPTV with version 1.0.9.18 and wrote to JamesGL via personal messages. Support gave me beta version with fixes.
- HWAMJan 13, 2018ApprenticeHave patience, are you kidding? I spend more than two weeks trying to make the router more or less stable. I tried anything. Read all the pages! It started a long time ago. And now I must be patient. I had to buy another router because I can't effort down time. And experimenting with Tomato or something else was also not easy with a business to run. We all payed for a working router. They broke it!! And they are aware of it. But helping me with a replacement or another solution NO! I tried betas, no positive results. So don't tell me to be patient. I am up and running with a new brand. No Netgear for me ever again. I only want to know what is going on, did they find any bugs. Just keep us informed. Not only a useless answer. We have the right to know what the status is.
