JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Wirewalker
Jan 14, 2018Aspirant
I bought mine new about 2 weeks ago so I didnt have any experience on any other version of software but I did lose my connected home thermostate when moving to this new router. After about an hour of playing around, I found that if you back your max speed down to the middle selection (286?) you will be able to connect your older devices. I think the new max is 600mbps. on my old netgear the max was 500mbps. On the fastest setting the thermostate wouldnt "see" the 2.4Ghz network. As soon as I changed that setting it showed up, connected, and I havent had a drop since (about a week). Hope this helps.
