JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Jan 14, 2018Apprentice
aabshire Did they say they found any bugs? Were they able to reproduce the problem at their development department? Do you have more information?
aabshire
I did not inquire into all the details but can say they requested devices with software versions, etc. in order to setup the invironment in their lab. I know they had their wifi hardware vendor involved and some of the updates/ debuging file came from them. Also there was something about QoS table and needing to update the database, even if not using QoS, due to them finding some android packet drops in that version.
