JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JTB5
Jan 15, 2018Aspirant
Not sure if anyone has seen this article
https://9to5google.com/2018/01/15/google-chromecast-home-wifi-outage/amp/
HWAM
Jan 15, 2018Apprentice
JamesGL droman Give us information and stop those useless discussions!!!!
Come on Netgear, community!!!
- mzguyJan 15, 2018Apprentice
Come on Netgear, community!!!While I admire your asking for their input, I fear they simply don't have much to say. If Netgear damaged the hardware, they probably never will reveal the cause of the problems... they'll just reduce the performance until the electronics stay within a tolerable range. Most users won't notice or care.
Even if Netgear "fixes" the issue, I would like to see two things, to be willing to reconsider Netgear in the future:
- An explanation of why reverting to previous firmware didn't fix the issue, so that we know that they understand the cause of the problem and how to prevent it from happening again with any future firmware upgrades.
- Compensation to customerswho had to put up with problems for over a month while Netgear said little to nothing. Many of these customers, like me, had no choice but to go out and spend money on a different router.
I don't have high hopes, but I would love to be proved wrong.
- potamus29Jan 15, 2018Guide
Thanks for the link JTB5 but it has nothing to do with the probems that I and many others experienced. I don't have a Chromecast. The droppinh of wifi connectons was purely related to the new firmware. Reverting back to an earlier FW has cured the problem for me so far, unlike some others it would seem. As far as I am concerned Netgear has left many people high and dry, if the outages return to mine I won't waste any more time looking for an answer, it will be new router, different brand.
- Diggie3Jan 15, 2018LuminaryTo summarize my thoughts:
- NG left this situation running far too long
- Their public communication has been very poor
- They have been working behind the scenes with a number of users to debug and test new builds, but I suspect this has been hampered by a situation where they seemed to begin engagement after the Christmas holidays when people a) were already exhausted of debugging and possibly bought new devices, and b) had less time to help them because they had returned to work.
- They seem to believe, and some users are confirming, that they have a build that seems stable in test now. I would personally expect to see a beta/hotfix out this week, given how badly this is affecting people.
- Nothing seems to have been "damaged" in the router. People can roll back to 1.0.7 and it works. People can change to AT or Vortex and it works. It is a shame that end users had to do all the legwork to find usable versions.
- Yes, the dearth of public engagement, updates, is infuriating.
I think at this point the best plan is to wait to see what they drop this week. That's my $.02.
NG: You better at minimum get a beta out via the forum ;) - Diggie3Jan 15, 2018Luminary1.0.7.12 is stable for me and I've seen others say it also has been stable for them. However, it does undo various security improvements I believe.
Diggie3 wrote:
1.0.7.12 is stable for me and I've seen others say it also has been stable for them. However, it does undo various security improvements I believe.Oh - I was unaware of that. I thought you took that statement back, but perhaps that was for a different version. How long has it been running stable for you?
- Diggie3Jan 15, 2018LuminaryOver a week.
I rolled back to FW version 1.0.9.10_1.2.21 six days ago, still ok, no drops.
- ENuffJan 15, 2018Initiate
I've had my R7000 for three years and have had lots of connect/disconnect issues, poor range and stability, most everything detailed in this topic and others, just overall bad performance. I've probably read every thread in this forum regarding software updates and the problems continue. If I do a 30-30-30 reset, then install an update, performance is reasonably stable until I mess up by forgetting and installing the next update without clearing the firmware first. A factory reset won't work, only the radical reset.
So, after enduring the equivalent of a car that may or may not start, may or may not keep running, may or may not allow itself to be refueled, etc., I installed XWRT-Vortex (just install it like an update, super simple!) a week ago and the difference in performance is incredible. Perfect stability, 50 downloads at a time, ability to use all of my 175 Mb connection, LAN switch (netgear!) and printer both work correctly and can be discovered EVERY time, ethernet is as fast as it should be, wireless coverage at the opposite end of the house never disconnects (wouldn't even go that far with Netgear software).
Actually, now the router just acts like any decent router should. The R7000 hardware is fine, the software is awful and as they junk it up more and more adding analytics, that Disney Circle thing and whatever else to the weak parental controls, VPN, DDNS and try to support that stuff, I don't see how Netgear's software will ever function as it should.
I was very close to just trashing our R7000 and buying another brand but XWRT-Vortex works so well, there's no point. If I'm somehow forced to use Netgear software again, out the Nighthawk goes.
- HWAMJan 15, 2018Apprentice
mzguy wrote:
Diggie3 wrote:
- Nothing seems to have been "damaged" in the router. People can roll back to 1.0.7 and it works. People can change to AT or Vortex and it works.Which user has reported success rolling back to any version of Netgear firmware and running stable?
mzguy Diggie3 NOT FOR ME. Even an old version wasn't stable anymore. I tried a lot of software and hardware resets and even the oldest firmware. I tried also 1.0.7.
