JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Firepsych
Jan 16, 2018Aspirant
I have 2 Google Home mini's on the XRWT Vortex (latest) firmware and have had no problems with them. Not sure if this firmware is more robust or if it an interaction with NG firmware that is causing some problems.
rogier64
Jan 16, 2018Luminary
Firepsych wrote:I have 2 Google Home mini's on the XRWT Vortex (latest) firmware and have had no problems with them. Not sure if this firmware is more robust or if it an interaction with NG firmware that is causing some problems.
Just far more robust in respect to NG firmware :-)
