JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
MannyN
Jan 16, 2018Aspirant
Per this article, google home devices may be causing issues with routers, including Netgear.
http://www.businessinsider.com/google-casting-devices-causing-problems-home-wifi-networks-2018-1
For the folks involved in testing activities with netgear support, you may want to disconnect Google hone devices and test.
- hellspawn69Jan 16, 2018GuideMy Google Home and Chromecast and Chromecast Ultra are still up and running, only the changes mentioned in my previous posts were needed to fix the 2.4 GHz issue.
- HWAMJan 16, 2018ApprenticeSTOP MENTIONING ABOUT GOOGLE HOME AND CHROMECAST IN THIS POST.
The problem here has nothing to do with the Google issue!!
