JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
rancidio
Jan 17, 2018Aspirant
I upgrade to this firmware after i have encountered the following problems
NAS synology connect to ethernet see all internal LAN but not connect to internet
All android device same problem, connect to internal LAN but not connect to internet
Downgrade firmware R7000 to V1.0.9.14_1.2.25 the problem has disappeared
the firmware 1.0.9.18_1.2.27 has problems
Regards
AlpineKid66
Jan 17, 2018Guide
I am using V1.0.9.14_1.2.25 and have one Android phone with no drops.
Am not using anything Google.
Have 2 laptops running at 5GHz. One is on most of the day to listen to WCMU public radio. Nice clear all day until kids get home and we all start using the net. Then I get break in the radio.
Have iPad and 3 iPhones using 2.4GHz. And we use Wi-Fi to make phone calls, no problems.
