JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AlpineKid66
Jan 18, 2018Guide
Nobody is talking about this anymore??
Robb_H
Jan 18, 2018Tutor
AlpineKid66 wrote:Nobody is talking about this anymore??
There's really not much that hasn't already been said, multiple times. Netgear could make a meaningful statement, but all that most of the rest of us could contribute would just be chatter.
- hellspawn69Jan 18, 2018GuideMy fix works. Someone who hasn't loaded custom firmware is welcome to check it out. Takes no time to make the changes I did, and mine has 0 issues dropping the 2.4GHz bands now.
Just trying to help fellow frustrated customers out since Netgear doesn't seem to be. - AlpineKid66Jan 18, 2018Guide
It is not that I wanted things to be rehashed, I was hoping that Netgear had done something with the firmware that is being tested. Was/is anything going on.
I would like to update fireware to the latest so that I can find out if that firmware will fix a different problem I have. If it dosen't, I fix it another way.
Hope the firmware is stable.
