JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mhsu858
Jan 18, 2018Guide
This lucky combination fixed my problem (staying with 1.0.9.18). stable for 10 days now. before, I had to reboot router 2-3 times a day for dropped devices to reconnect (getting stuck at getting IP). I have 23 devices, 5 of them google phone/home.
router config:
use smart connect - single SSID for 2.4 and 5G
use Google DNS
Use reserved IP for all devices
no guest network
no QoS
no UPnP
no readyShare
WAN setup - defaults
LAN setup - defaults + add address reservations
WPS - disabled
Wireless setting -
2.4G - channel - 1 (found weakest neighbor -95 dBm on channel 1)
WPA2-PSK
enable 20/40 coexist
5G - channel 40 (not able to see neighbor's)
mhsu858
Jan 18, 2018Guide
And, should not forget this seems to be the most important one for me:
Enable "Access Control" but allow any device to connect
