JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
ibrouwer
Jan 18, 2018Initiate
Hi All,
After a pb invitation, I upgraded firmware with a debug version. At the moment the disconnect problem occurred (within several hours) I uploaded the debug logs.
I quickly received another debug version of the firmware and uploaded that one yesterday.
Netgear is certainly working on it.
That version is running fine without any disconnect problems for more than 24 hours now.
Looks like they fixed the problem in that version.
See how it continues the coming days.
So far so good.
- TerryPhJan 18, 2018VirtuosoThey are working hard to debug FW for R8000
Possibly nailed out to a common root cause of problem
I have tested multiple trials FW sent from them, and they have good record of the debug logs.
Hopefully they are now in the right track to get it fixed.- HWAMJan 18, 2018ApprenticeMy new Linksys wrt1900acs solved the problem and I will never buy a Netgear router ever again.
- TerryPhJan 18, 2018VirtuosoTo HWAM.
Big congratulation to get the new router. Finally you get your peaceful life back. Sincerely hope that you will never be stretched out again for these kinds of problem, technically speaking...
Best
Terry
