JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
parker3
Jan 20, 2018Aspirant
I received the email to upgrade the firmware. This morning I followed all directions and now several Roku's and FireSticks and my cell phone won't connect. Other devices are connecting. This has been driving me crazy all day. How can I go back to the old firmware, when everything worked flawlessly. Is there anything I can do to fix this? I noticed it's set to AP - is this corrrect? Is there another setting it should be on, and if so, How do I change it? I don't have any Google or Chromecast devices. Thanks for any help!
rogier64
Jan 20, 2018Luminary
You can go back to the older firmware but probably it won't solve your problem. Just flash an old firmware for R7000 the same way you flashed the new firmware, you only get a warning that the firmware will be older than installed and have to accept it. Right now the only way to fix your problem is flashing an alternative firmware.
- parker3Jan 20, 2018Aspirant
Thank you for the informed reply. I'll give that a try and report back. Where can I find the alternative firmware you speak of. I'm very grateful for your help, I have average tech skills and I'm learning alot just reading. I'm all googled out! I'm glad I found this forum. Your's is the first sugestion that makes sense and it's something simple I can understand and do myself. Got my fingers crossed...I'm extremely motivated to solve this issue. :)
- rogier64Jan 20, 2018Luminary
parker3 wrote:Thank you for the informed reply. I'll give that a try and report back. Where can I find the alternative firmware you speak of. I'm very grateful for your help, I have average tech skills and I'm learning alot just reading. I'm all googled out! I'm glad I found this forum. Your's is the first sugestion that makes sense and it's something simple I can understand and do myself. Got my fingers crossed...I'm extremely motivated to solve this issue. :)
There are several alternative firmwares for the R7000 like Advanced Tomato, DD-WRT and XWRT-Vortex. I'm using XWRT-Vortex which I find it's the best. It's based on AsusWRT and can be flashed the same way you flash NG firmware. Be aware that reverting is less easy, but once installed you probably won't go back. Just Google on XWRT-Vortex for reviews and download link, latest version is 380.69.
- kiotobgJan 21, 2018Guide
XWRT-Vortex and Shibby Tomato have a option to schedule turning on/off wifi?
Because they not have a full documentation.
