JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Diggie3
Jan 20, 2018Luminary
Really... 713 posts on the topic in this thread alone, and that's what you're going to ask?
Junopapa
Jan 20, 2018Tutor
You are fair to say this but, I was reading about wireless drop-off complaints. Before I continued to read another 700 posts on the same topic, I posted about internet connectivity. I'm seeing strong wifi signal but my Netgear CM500 modem is dropping intermittantly after the 1.0.9.18 update this morning. I was thinking a different issue. The problem is corrected by re-booting the modem and not the router.
- rogier64Jan 20, 2018Luminary
Junopapa wrote:
Diggie3 wrote:
Really... 713 posts on the topic in this thread alone, and that's what you're going to ask?You are fair to say this but, I was reading about wireless drop-off complaints. Before I continued to read another 700 posts on the same topic, I posted about internet connectivity. I'm seeing strong wifi signal but my Netgear CM500 modem is dropping intermittantly after the 1.0.9.18 update this morning. I was thinking a different issue. The problem is corrected by re-booting the modem and not the router.
Dropping and reconnecting WAN to LAN is also one of the issues caused by the latest firmware as well as a spontaneous reboot of the router.
