JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
shamarin
Jan 25, 2018Virtuoso
New beta is available https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
aabshire
Jan 25, 2018Apprentice
I have been running a pre-release of this with no issues for several days
- dromanJan 25, 2018NETGEAR Employee Retired
Latest update for R7000 as of 8:00AM (Pacific Time), January 25, 2018
Here’s the latest update on the R7000. We have released a hot fix that you can obtain by going to our knowledgebase article title “R7000 Firmware Version 1.0.9.26” which contains a link to download the firmware. This hot fix should help with the Wi-Fi disconnects. We also still recommend you also update you Android and Chromecast built in devices with the latest updates from Google. The feedback provided by community users who have helped test, as well as, the testing in our labs have been invaluable in creating this hot fix. However, even though this hot fix should alleviate the disconnects, we still want to hear from users of any further issues after the installation of the hot fix. As always, we very much appreciate our users and the continued conversation in the community. I see others have already posted the link to the KB but wanted to get this post out as well.
Thanks, Dave
- sorin_popescuJan 26, 2018Tutor
droman, has netgear fixed in this beta version the pppoe ipv6 problem? or i have to stick to my beta 1.7.3?
Thanks
- bobgodfreyJan 26, 2018Aspirant
Can anyone tell me why after flashing to the Firmware version 1.0.7.12 the GUI version would still be 1.0.9.18? I did a reset after the flash
