JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
iRog
Jan 25, 2018Tutor
There seems to be a bug in this firmware release. Since I updated to V1.0.9.18_1.2.27, my Naim MuSo media player is no longer able to connect to internet radio stations. I dont have access controll enabled and I dont have any sites blocked.
Updating to 1.0.9.20 beta did not fix the problem. Rolling back to 1.0.9.14 restores streaming.
- shamarinJan 25, 2018Virtuoso
Did you try the latest beta firmware version 1.0.9.26?
- iRogJan 25, 2018Tutor
Now resolved by 1.0.9.26 :smileyhappy:
- aabshireJan 25, 2018Apprentice
Great
I new hot fix came out today.
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
