JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
iRog
Jan 25, 2018Tutor
There seems to be a bug in this firmware release. Since I updated to V1.0.9.18_1.2.27, my Naim MuSo media player is no longer able to connect to internet radio stations. I dont have access controll enabled and I dont have any sites blocked.
Updating to 1.0.9.20 beta did not fix the problem. Rolling back to 1.0.9.14 restores streaming.
shamarin
Jan 25, 2018Virtuoso
Did you try the latest beta firmware version 1.0.9.26?
