JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Yann7878
Jan 27, 2018Tutor
I tried the new beta firmware 1.0.9.26 .... but created disconnects on Lan ..... I guess that's why it is still beta. Back to 1.0.7.10_1.2.3 that works flawlessly.
- matedJan 27, 2018Aspirant
I also tried the new beta firmware 1.0.9.26 (was on 1.0.9.20) -- still getting drops on 2.4 GHz
- aabshireJan 27, 2018Apprentice
Stange, I have been on for over 60 hours and no disconnects on 2.4 or 5 GHZ
- tivoboyJan 27, 2018Guide
Can one still get the1.0.7.10_1.2.3 somewhere?
- shamarinJan 28, 2018Virtuoso
- antinodeJan 28, 2018Guru
> Ofcourse, https://kb.netgear.com/000037100/R7000-Firmware-Version-1-0-7-10
More generally, visit http://netgear.com/support , put in your model
number, and look for Downloads. Under Firmware and Software Downloads,
look for View Previous Versions. Download the kit you want. Read the
"Release Notes" file for instructions.
