JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
shamarin
Jan 28, 2018Virtuoso
I knew about it and where to find. Now i use the latest beta and has no issues with Wi-Fi. And even with 1.0.9.18 didn't have.
Peet45
Jan 28, 2018Aspirant
Well I have a strange issue with my R7000 routers after upgrading to the new firmware. What’s even stranger is that I don't have all those Wi-Fi issues that everyone has been describing here. My Wi-Fi devices work fine with the previous firmware and have been working fine since I got the routers 1.5 years ago. Except when I upgraded to the latest firmware I lost all port forwarding with my camera system and nothing seems to be able to fix that. I tried resetting the router and the camera system, changing ports and many other things but nothing seems to help. And when I revert back to the previous firmware in order to get the ports sharing going again I had to change all of those ports used by camera system. The router would not forward those same ports for some unknown reason. What’s even more bizarre is that I have ADSB receiver that also has ports forwarded and that seems to work fine even with the new router firmware. I hope someone from Netgear can share some info on this issue because I never had any problems like those before. I have r7000 and r9000 working at several different locations and replacing them is not an option for me. Thanks
