JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JamesGL
Jan 28, 2018NETGEAR Employee Retired
Hi bobgodfrey,
Have you tried to reset the router after the update?
Hi hurricane28,
Please confirm if you already tried the hot fix firmware. We may need your feedback on this.
Hi Robb_H,
When you update the firmware, did you reset after?
Do you have any google home devices on your network?
Hi mated,
How many device on your LAN network that were having disconnection?
When using the hot fix firmware, did you encounter disconnection on wireless devices specifically on 2.4GHz?
Have you performed a factory reset?
Hi Peet45,
Which firmware works with port forwarding?
What error message did you encounter on the devices?
Please provide the port numbers that did not work.
Hi pfarmerca,
Are you still using the latest firmware? Hows the performance after the one drop? Please try to reset after the update if you are still experiencing disconnection.
hurricane28
Jan 28, 2018Guide
Hi,
Sorry, i haven't tested the new firmware yet, i was quite busy with my PC. I am stil on V1.0.9.14_1.2.25 and have no issues that i know of.
I am not sure if i am comfortable flashing the new firmware bu if there are more positive feedback from users i might give it a try.
- sorin_popescuJan 29, 2018Tutor
JamesGL has netgear fixed in this beta version the pppoe ipv6 problem? or i have to stick to my custom beta 1.7.3?
Why do we have to run old firmware with security issues because netgear doesn't care about pppoe ipv6?
Very very disappointed.
