JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
liquidiq
Feb 02, 2018Aspirant
Model: R7000
Firmware: 1.0.9.26
Updated to .26 last night, did a full paper-clip factory reset. Now I'm experiencing that my Sonos speakers are not being detected on the network. I've rebooted the speakers, and they will come up for a bit then disappear. They all run on the 2.4GHz channel. .20 did not exhibit this behavior. I'll roll back to that version.
