JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JamesGL
Feb 08, 2018NETGEAR Employee Retired
Hi Redtarheelhawk ,
1. Many of you seem to have updated to the latest beta and still experience the issue. Is this true? -Many users have confirmed that the issue has been fix with the latest hotfix. You have to check as well if you have google home devices or chromecast or any other device the uses casts feature that contributes to the issue. There is a known issue with those devices.
2. I don’t like betas and am scared to move off of 1.07 for fear the issue will come back with the latest release. - This is considered as official firmware since it is released in official website.
3. I am unclear what risks and security holes exist in 1.07 and am worried about being on this old version too long. - Then you might have to consider upgrading to the latest firmware. Please take note that not all users have the same environment and network setup.
4. I have seen nothing from netgear that officially admits to the problem, explains the root cause, and communicates to all of us when an official fully 100% tested release will be available. - It has been confirmed by NETGEAR that it is an issue that is why the firmware was released.
potamus29
Feb 09, 2018Guide
The hotfix is by no means a complete solution as evidenced by those with continuing problems. I used screen cast on an earlier firmware without problems. It's Netgear that has the problem, trying to pass it to others is pretty poor.
If it is considered official firmware why does the broken 1.0.9.18 remain as the first download available?
Or you may consider moving to a third party frimware that does not have the issues provided by Netgear
Has it been admitted by Netgear that they have not completely fixed the problem, because they can't find what they did to break it? I've seen no explanatory communication from them, has anyone? An apology would be a start.
