JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
pierreca
Feb 13, 2018Aspirant
I did install the Chrome home app yesterday.
I ask you if smarconnect still works, doubt it.
Because i could not see configured chromacast device from the 5g wifi.
Both device have to be on 2.4g.
Did not bother trying both on 5g. My family want to use it.
Get this stuff fixed, Ive done my part.
schumaku
Feb 13, 2018Guru - Experienced User
All aware 1.0.9.26 is out? http://kb.netgear.com/en_US/000054779/
Bug Fixes:
- Fixes the Wi-Fi disconnect issue caused by a flood of broadcast traffic.
- Fixes security issues.
Bug Fixes:
