JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
illest33
Feb 14, 2018Aspirant
Wifi still drops on patch V1.0.9.26_10.2.31. Hard reboot every single day. Devices lose connection and are unable to rejoin the wireless networks. Channels are properly set to avoid interference. This has been going on for quite some time now. When will it be fixed? Is it a hardware issue that firmware cannot fix?
shamarin
Feb 14, 2018Virtuoso
Did you try to reset you device after an update?
- illest33Feb 15, 2018Aspirant
shamarinwrote:Did you try to reset you device after an update?
Reseting device does not change anything.
- Mr_DJFeb 19, 2018Apprentice
To those users still facing problems, using latest update 1.09.26....
Could you please try these steps:
1. After updating to the new firmware, please reset the router....Warning: this will delete any custom settings you have done to the router, so if you can't remember these settings(and need them), take a screenshot of the different menu setting pages and save them in paint as png files or just simply use the camera in your smartphone. DON'T use a backup file from a older firmware version.
Reset using following method: Press and hold in the reset button for at least 10 seconds and give the router a couple minutes to finish the reset cycle.
The Netgear login username and password, will now be back to factory default of "admin" and "password".
2. After updating firmware and resetting, the QoS database in the Netgear router will be deleted and needs to be re-downloaded, in order to fix wifi issues with speed and connectivity stability. And yes, though it may not seem like logic, but even if you don't have QoS enabled by default, the settings in the QoS database file is still used by your router for dealing with the wifi connections and will affect how the router deals with your wifi devices.
And as an extra precaution/optimization(especially if you experinced issues with stability), you may also want to re-setup the wifi profile on your Android devices(delete wifi and re-configure again). Some users, including myself, has experienced in the past that this can solve stability issues with wifi connections on Android devices.
Let me/us know if these steps helped you with your particular problem. Thanks!!
Edit: I haven't experimentet myself, so this is just a thought on my part, but I personally have always disabled the Netgear data collection service and Disney parental options. You may try the same, if still having problems and facing issues.
Found this quick guide, on how to download new QoS database file(for those who needs it):
Step 1. Go to QoS Setup (you'll find this option under advanced/setup/QoS Setup/)
Step 2. Put a checkmark in "enable QoS" scroll down and then click on the "Update Now" button in front of the "Automatically update performance optimization database " option. Wait for it to update.
Step 3. Remove the checkmark(important) on the "enable QoS" again and click on the green "Apply" button at the top of QoS menu.
Step 4. Log-out and do a new speedtest and now (hopefully) enjoy your new faster wifi speed! ;-)
Another tip:
To check for potential wifi issues related to sharing your 2.4GHz/5Ghz wifi frequencie channels with neighbours, please download the app(on Android smartphone or tablet)called "wifi analyzer" and check if you are sharing wifi channels with a neighbour. If there is a free channel try changing your Netgear router to this channel instead. Or if no channels are free, choose the channel with the weakest signals coming from your neighbours.
