JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Bob254
Feb 21, 2018Guide
Upgraded to 1.09.26 on the 18th (little irony there). Upgrade smooth, router rebooted on it's own. Came back online with no fuss. As far as I can tell, all my previous settings remain. Both 2.4 and 5Ghz bands are turned on as it was prior to the upgrade.
No connections issues or drops. No lag or buffering, even with 3 devices simultaneously playing 1080P youtube videos.
Have devices hardwired to the R7000 and none of those exhibit any connectivity issues. I do not have any Google/android devices. Wifi connected devices run Linux Mint, Windows and iOS.
Looking good so far.
