JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Dec 19, 2017Apprentice
Just ordered a Linksys WRT1900ACS. I am so sick and tired.
Donth
Mar 05, 2018Aspirant
Irony someone moved to linksys. I bought the netgear after my linksys keep dropping all the 2.4 and 5 connections and tech support gave me the run around after I tried all the firmware updates and factory resets. When they gave me a hard time about a warranty return, I called it quits on a 1 year old $300 router and came here. I think was a design or chipset problem which can't be fixed sometimes because the linksys forums have tons of people in basic configurations with similar issues who jump through hoops to get their routers basic functions to work
BTW Belkin bought linksys. They aren't the same company they used to be.
- AlfikMar 06, 2018Aspirant
- FURRYe38Mar 07, 2018Guru - Experienced User
- hurricane28Mar 09, 2018Guide
Can someone tell me what Tomato is and how to flash it plz? I want to stream movies but its not possible with this crappy firmware.. If this doesn't get solved i return this thing to the retail store and get something else that DOES work..
thank you.
