JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Alfik
Mar 06, 2018Aspirant
Mar 07, 2018Guru - Experienced User
- hurricane28Mar 09, 2018Guide
Can someone tell me what Tomato is and how to flash it plz? I want to stream movies but its not possible with this crappy firmware.. If this doesn't get solved i return this thing to the retail store and get something else that DOES work..
thank you.
- KitsapMar 09, 2018Master
Try this: http://bestwirelessroutersnow.com/dd-wrt-vs-tomato-vs-openwrt/
Remember, Google is your friend.
- hurricane28Mar 10, 2018Guide
Thnx for the link.
I know google is my friend, but because a lot of people in this thread are talking about tomato etc. its only logical to ask here..
