JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Diggie3
Mar 11, 2018Luminary
The NG firmware overrides the lookup for www.routerlogin.net and returns the router IP for it. If you are not using the router's DNS server it won't work. Just go directly to http://192.168.1.1, or whatever you have the router at.
Retired_Member
Mar 11, 2018Hmm ok, thanks. I have been going straight to http://192.168.1.1 and it keeps redirecting me back. I'll try setting my DNS manually to that of 192.168.1.1
Thanks
