JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
pierreca
Mar 31, 2018Aspirant
No not been fixed by Netgear.
have moved on to third party firmware.
No issues.Router has never worked better.
Don't even know its there now, everything works and is stable.
Wireless works, no disconnects, Media streaming doesn't choke any more.
Net-working
Apr 01, 2018Guide
Really!!
I noticed that the firmware was now on 1.0.9.26 so though everything must have been fixed by now.
- YugiohApr 01, 2018Tutor
I took the plunge and installed Tomato and no wifi drops. Pretty simple to install. I also run some linux computers and I am now able to print from linux to the network printer.
