alpinac2
Aug 04, 2016Aspirant
Fehlendes Arlo-Menu nach Firmwareupdate / Missing Arlo-menu after firmware-update
Nach dem Firmwareupdate auf Version 1.0.7.2 fehlt das Arlo-Menu und die Kameras können nicht aufgerufen werden. Was kann man da tun? After the firmware-update on Version 1.0.7.2 the Arlo-menu is ...
- Aug 04, 2016
problem solevd, the reason were different versions (firmware and GUI language version)!
Retired_Member
Aug 04, 2016I guess you missed my post, revert to previous version like I did.
JamesGL
Aug 04, 2016NETGEAR Employee Retired
Hi alpinac2,
The v1.0.7.2 firmware has no Arlo feature. If you have an Arlo system, continue to use the beta firmware with Arlo support.
JamesGL
Community Team
