alpinac2
Aug 04, 2016Aspirant
Fehlendes Arlo-Menu nach Firmwareupdate / Missing Arlo-menu after firmware-update
Nach dem Firmwareupdate auf Version 1.0.7.2 fehlt das Arlo-Menu und die Kameras können nicht aufgerufen werden. Was kann man da tun? After the firmware-update on Version 1.0.7.2 the Arlo-menu is ...
- Aug 04, 2016
problem solevd, the reason were different versions (firmware and GUI language version)!
alpinac2
- JamesGLAug 04, 2016NETGEAR Employee Retired
Hi alpinac2,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!JamesGL
Community Team
