Lakshman9's avatar
Lakshman9
Follower
Oct 08, 2021
Fiber connection to my Netgear with missing Ethernet in port
Hi,
We have Xfinity cable internet connection (100 mbps download) with Negear C6250 model. I am switching to Ziply fibre (200 mbps download speed) but this requires Ethernet in port on my router which is not present on my router. Is there any work around to use my current router or do I have to buy a new router which can support fiber with Ethernet in port?
1 Reply
  • FURRYe38's avatar
    You can't use the C series cable modem on a Figer ISP service line. You'll need to find a R, RAX or Orbi R series external router to connect to the Fiber ONT device. Contact the ISP for help and information regarding there support of routers on there network.
    Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
    Thank you.
