Sinisterj12
May 18, 2016Tutor
File format Not supported DLNA w/Servio
I've been streaming more lately with netflix and movies across the network so i decided i would get a new router to handle everything so i got the nighthawk r7000 router. My old router was a Netgear...
- May 25, 2016
Thank you for your reply but i did figure this out. When i installed the new router my Serviio also took on an update. I had to update my rendering profiles on Serviio then it worked.
DexterJB
May 24, 2016NETGEAR Moderator
Hi Sinisterj12,
1. The media server option on the router only applies if you are using the ReadySHARE feature of the router.
2. Are the other devices in the network (other than the TV) able to stream the files?
3. Have you tried other media server software/apps?
Dexter
Community Team
Sinisterj12
May 25, 2016Tutor
- DexterJBMay 25, 2016NETGEAR Moderator
