Sinisterj12
May 18, 2016Tutor
File format Not supported DLNA w/Servio
I've been streaming more lately with netflix and movies across the network so i decided i would get a new router to handle everything so i got the nighthawk r7000 router. My old router was a Netgear...
- May 25, 2016
Thank you for your reply but i did figure this out. When i installed the new router my Serviio also took on an update. I had to update my rendering profiles on Serviio then it worked.
Sinisterj12
May 25, 2016Tutor
DexterJB
May 25, 2016NETGEAR Moderator
