twisted9000
Mar 04, 2021Aspirant
Find firmware version from admin local site?
Hello, is there a way to find the firmware version from admin local site? It keeps wanting me to do Insight which I don't won't to do. Where do I find this by the admin page by the router IP address?...
michaelkenward
Mar 05, 2021Guru - Experienced User
twisted9000 wrote:
....admin local site?
What's that?
Not sure what that means, but the "Home" page at http://routerlogin.com/index.htm has a bold Router Firmware Version tag at the top right.
Again, I have no idea what that means.
I seem to be a bit slow today.
- twisted9000Mar 05, 2021Aspirant
Sorry not to clarify. By local admin connection I mean by internal IP address like 192.168.1.1. From there it doesn't show anything about the firmware. I can see it in Smart Control Center, but 1/2 the time when I try to connect it won't find the router. By internal IP address I can do it everytime, it just doesn't list it there unless it's under Software Version?
- michaelkenwardMar 05, 2021Guru - Experienced User
It is there when I go to that page:
It is one of the most obvious things there. Where are you looking?
There are other ways, but that is the easiest.
- antinodeMar 05, 2021Guru
> [...] is there a way to find the firmware version from admin local
> site? [...]I'd assume so, but I know nothing. Have you tried the obvious?:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"firmware"? I know nothing, but I might start with "System" or
"Maintenance".
> [...] Also our current firmware is 6.0.4.2 but on the netgear download
> page it says 6.0.1.30 is the latest._Which_ "the netgear download page"? I see "Firmwareversion [sic]
6.0.6.2".https://www.netgear.com/support/product/GS752TPv2.aspx#download
for Downloads?
> What's that?He means the management web site of his device. This could be
confusing to someone who insists that a "web site" must reside on the
far side of the planet, and not in a device on the table a meter away.> It is there when I go to that page:
You're looking at the management web site of your consumer-grade
router, not that of his "Smart Managed Pro Switch".> Model: GS752TPv2|48-Port Gigabit Ethernet PoE+ Smart Managed Pro
> Switch with 4 SFP Ports (380W)https://community.netgear.com/t5/x/bd-p/business-smart-plus-click-switches
