Kaumans1
Jan 03, 2022Follower
Fios ONT Reset
Has anyone had to reset their FIOS ONT to factory settings? If so, does that mean I have to subsequently reset my nighthawk R9000 router and essentially re-establish my e tire network??
1 Reply
Contact the ISP about resetting there hardware.
No you should not reset your R9000 router.
A power OFF off the router for 1 minute after the ONT is reset maybe needed though.
