actionfast
Mar 07, 2023Guide
Firestick on LAN
Hi, I have a LAN line direct from my Nighthawk to my Firestick (with the adapter) The Firestick does not find the router, it will only connect wi-fi. I get too much buffering, I want to go wired. Wha...
Mar 07, 2023Guru - Experienced User
Contact the mfr of Firestick.
Possible it doesn't support ethernet connections.
actionfast
Mar 08, 2023Guide
Yeah, it is meant to. I specifically bought the Amazon adapter for the Firestick, to allow a LAN connection. I run a LAN from the router to the adapter, then micro USB from the adapter to the Firestick.
