actionfast
Mar 07, 2023Guide
Firestick on LAN
Hi, I have a LAN line direct from my Nighthawk to my Firestick (with the adapter) The Firestick does not find the router, it will only connect wi-fi. I get too much buffering, I want to go wired. Wha...
actionfast
Mar 08, 2023Guide
I bought the specific Amazon adapter meant for their Firestick. I tried to get a replacement, but Amazon refused, so I cannot say 100% the adapter is not at fault.....
Mar 08, 2023Guru - Experienced User
blinking amber means its connecting at 10/100mbps link. Which is normal. those adapters aren't gigabit speeds. so amber is normal. And its means its connecting to it.
Did you re-run the network setup on the firestick?
- actionfastMar 08, 2023Guide
yes, and it only sees wi fi
- plemansMar 08, 2023Guru - Experienced User
How long is your wired power cable?
Have you tried a different power adapter? (with enough amps)
From reading the forums, the factory adapters have issues if underpowered and the ethernet won't work.
Might be worth checking.
I'd read a bit on the reviews for that specific device. Like I said, if the ethernet port light is coming on, the router is picking up a connection.
- michaelkenwardMar 08, 2023Guru - Experienced User
Did you ever tell us what Netgear router you have and what modem it talks to?
