actionfast
Mar 07, 2023Guide
Firestick on LAN
Hi, I have a LAN line direct from my Nighthawk to my Firestick (with the adapter) The Firestick does not find the router, it will only connect wi-fi. I get too much buffering, I want to go wired. Wha...
actionfast
Mar 08, 2023Guide
I never thought of that, i am using the one that came with the Firestick. I really don't even know where I'd go for other options.
The power cord is maybe 3-5 feet
Mar 08, 2023Guru - Experienced User
are you powering it off the tv usb port or a wall plug?
If its a wall plug, see if you have a 2amp one around. Most firesticks only need 1 amp but maybe the distance/adapters have caused it to need more.
- actionfastMar 08, 2023Guide
So, any 2 amp micro USB should work?
- plemansMar 08, 2023Guru - Experienced User
In theory yes.
Also make sure the firestick is updated. Seems like some of the updates have issues with the adapter (from reading reviews)
I'll give it a try, thanks
