actionfast
Mar 07, 2023Guide
Firestick on LAN
Hi, I have a LAN line direct from my Nighthawk to my Firestick (with the adapter) The Firestick does not find the router, it will only connect wi-fi. I get too much buffering, I want to go wired. Wha...
ocasaenva
Mar 09, 2023Aspirant
My internet speed is a true 300-320 Mbps. My Fire stick 4K Max is getting 3-5 Mbps. I've rebooted both the router and the Fire Stick. Wifi connection. Tried both 2.4 and 5G. It's 3 feet from the router, a NETGEAR Nighthawk Wifi 6 capable router. It's not blocked by the TV, as used my phone's NETGEAR scanning app and it works fine when held right beside the fire stick, no significant decrease in signal. It is indeed in a wall outlet with the included power block. My phone is getting 300+ up and down, don't understand why the stick is getting damn near dial-up speeds.
Mar 09, 2023Guru - Experienced User
Seems like if other devices are working to get to spec speeds and the Firestick isn't, seems like the stick is the problem or faulty and not working right. Something Amazon should look into.
