Cmnessler
Nov 27, 2018Aspirant
Firewall issue R7000
Just a quick back story: I have 2 security cameras installed on my network, but I am currently unable to access their feed on my phone app when my phone is not on the same network. (This was not an is...
- Nov 28, 2018Yes this is the obvious choice. And it was a simple question.
I am sorry I came to this community and asked questions. I clearly should have known better.
Cmnessler
Nov 28, 2018Aspirant
Thanks for your help! Remember, this is all new to me.
The cameras are a Wansview K1 and a Wansview K3. I access their feeds on the app provided by Wansview with the purchase of their cameras. I have an iPhone 8 and the OS is up to date.
Thank you in advance for your patience with me.
IrvSp
Nov 28, 2018Master
Thanks for the camera info.
I need to KNOW if you followed these Instructions, https://www.cameraftp.com/CameraFTP/Support/Wansview_M625W_NCM620GA_NCM751GA_NCM622GA_Others_CloudRecording.htm
as it seems this might make some configuration changes?
Also on this page, http://www.wansview.com/Service/download/27.html as there are USER MANUALS in various languages, and for the K1 Section 5 details Web Access Setup.
It is ALL new to me too as I don't have that h/w. However after looking at both links above and your comment that it worked before on a LinkSys I'm assuming you did NOT re-setup the camera's for the Netgear, hence your problem, especially if there is a different IP Address for the Netgear router vs. the LinkSys.
- CmnesslerNov 28, 2018Aspirant>I need to KNOW if you followed these Instructions, https://www.cameraftp.com/CameraFTP/Support/Wansview_M625W_NCM620GA_NCM751GA_NCM622GA_Others_CloudRe...
as it seems this might make some configuration changes?<
This link is not working for me, however in answering your question at the end, I have not done any re-setting up of my cameras. I was under the understanding (from Wansview) that this wasn’t necessary.
Honest opinion - do you think this will be an easy fix, or something that will be quite extensive? I am not confident in my abilities if this will need to turn into a large work around. ☹️- IrvSpNov 28, 2018Master
That LINK works fine for me, but not the one you copied in your reply?
From what I'm reading on that link when you change any network settings (or even the network) you have to RESETUP the whole system.
Read that link and the USER MANUAL.
I can't help you from here at all.
Cmnessler wrote:
Honest opinion - do you think this will be an easy fix, or something that will be quite extensive? I am not confident in my abilities if this will need to turn into a large work around. ☹️What choice do you have, either try to do it or live with it not working?
- CmnesslerNov 28, 2018AspirantYes this is the obvious choice. And it was a simple question.
